Chain slipping/skip...
[Closed] Chain slipping/skipping
[#3208744]
I've got an odd problem of the chain randomly skipping when on the smallest cassette sprocket.
Have a new cassette, new chain and new chainrings. Mech is adjusted well for shifting and the B-screw adjustment
Doesn't always skip when applying full power, but more on medium or as soon as I back-off from full power.
Only other thing I can think of it a stiff chain link. But there are no obvious ones I can see, haven't got around to manually checking them all yet.
Any other ideas?
Posted : 04/10/2011 8:16 am
Chain too long?
Posted : 04/10/2011 8:22 am
Check the jockey wheels on the mech
Posted : 04/10/2011 8:25 am
Your limit stop might be set very slightly too far inward for the smallest cog?
Posted : 04/10/2011 8:30 am
Cable routing? I had a similar problem and comparing the cable routing with the Shimano instructions found I had it the wrong way round. Quite a few internet forums suggested this was the problem so I switched it over. A combination of that, and going SS, seems to have cured it.
Posted : 04/10/2011 8:34 am
derailleur hanger alignment? Might have to take it lbs to check it though
Posted : 04/10/2011 8:48 am
Hey Matt,
I had the same problem in August. New jockey wheels cured it. Check if yours are looking a little pointy.
BTW, it didn't seem to be a problem on Wednesday night, or did I just miss it?
Posted : 07/10/2011 10:35 am
Had a very similar problem last year - would skip under power and on bumpy trails. Turned out when I had replaced the cable I had cut the outer to short under the BB thus when rear suspension compressed it tightened the cable.
Worth a check (if its a full susser)
Posted : 07/10/2011 11:11 am
Bent mech hanger... only needs a very small bend / twist to have an effect on shifting.
Posted : 07/10/2011 11:52 am
