I have one of the Crc lifeline tubeless track pump. The lever that changes from pump to air tank has snapped off. Does anyone have a spare chuck head from that type of pump
Or know where you can get spares/new chuck as crc don’t supply them ?
Thanks
Posted : 07/03/2019 9:31 pm
I think all the lever does is shut the air off coming out the valve and forces the pressure to then go inside the resevoir in the pump body.
If this is the case you could buy any head, some hose barb connectors, a 1/4 turn ball valve and fixings to stand the pressure you pump the tank up to. (200 psi iirc)
Posted : 07/03/2019 10:35 pm
