Chain length - long...
Chain length - long or short?
9 Users
1 Reactions
I broke my chain cycling the other day - so a new SRAM one has gone on.
I run an 11-50 cassette on the rear and 30 tooth chain ring.
The chain arrive at 126 links long - I have taken 10 links out - when on the 11 rear cog, the rear derailleur is at it's max take up , when it is on the 50 rear cog, it's not.
In theory I could take either another 2 or 4 links out - and it would be fine.
Is there any real world advantage in running a shorter (tighter?) chain
Thanks
Posted : 05/03/2023 7:35 pm
Too short is worse than too long with 1x. Sounds like its ok, if the mech cage doesn’t contact the mech in the highest gear (smallest cog)
Park’s measurement is worth following
Speaking from experience… i took 1 too many links out of the chain, was too short, so had to replace it. Either replace or have 2 quicklinks in.
Posted : 05/03/2023 7:45 pm
^ thanks for that,
I am probably there or there about
Posted : 05/03/2023 8:16 pm
I like to run them as short as possible. Less chain to rattle and flap about!
Posted : 05/03/2023 9:24 pm
I'll run it a is - but I can always take 2 links out
Posted : 05/03/2023 10:39 pm
The ideal setting is exactly as short as you can make it but the absolute worst setting is "a bit too short", while "a bit too long" isn't realyl much worse than perfect so if you're not sure, it's a no brainer to go long.
For 100% safety, take the shock out if applicable and cycle it through, in the biggest combo of cogs. But you can cut it finer than that because the odds of actually using the whole movement in that super low gear are pretty small, you're always likely to be in a middle or high gear when you hit the suspension hard. Of course not all bikes will have the "longest" chain length while fully compressed so you have to be careful of that too. So it becomes a judgement call after that.
Posted : 05/03/2023 11:06 pm
the odds of actually using the whole movement in that super low gear are pretty small, you’re always likely to be in a middle or high gear when you hit the suspension hard
As @Northwind says the min length ought to be ok in most situations as there's unlikely to be enough energy in the system at the low speeds you're going to be doing in the granny ring to fully compress the suspension. I think I always minimise my chain length with this in mind though I'm not sure it's a good thing with long cages and big rings as the longer the cage, the higher the chain angle.
Posted : 06/03/2023 11:30 am
For 11 and 12 speed experience tells me to start with the manufacturers stated method, anything else can lead issues as the top jockey wheel has a far bigger offset than good ol' 7/8/9/10
Posted : 06/03/2023 11:44 am
 drew
Not sure I entirely agree with the above. I've ruined a mech by granny ringing up a climb with slightly too short a chain and then forgetting to select a different gear before the descent. First sizeable compression and then bang.
Posted : 06/03/2023 11:48 am
 Yak
I would go as long as possible for wide-range cassettes and 12s. So where you are now is fine. Yeah, there may be an optimal 1-link-less possibility, but you won't go wrong with your set-up as it is.
Posted : 06/03/2023 11:55 am
 a11y
Not sure I entirely agree with the above. I’ve ruined a mech by granny ringing up a climb with slightly too short a chain and then forgetting to select a different gear before the descent. First sizeable compression and then bang.
Yep, not sure I agree either. Setting up a new bike at the weekend and I didn't appreciate just how much chain growth there was when the suspension compresses - it's a high pivot with a lot of rearwards axle travel, but even still I was surprised. Simply riding around the garden in granny gear and bumping over the path was enough to feel the suspension getting restricted by the too-short chain.
Given the bike isn't mine (Mrs a11y's) I didn't want the risk of issues so the chain's long enough to cope with full compression even in the granny gear.
Posted : 06/03/2023 12:04 pm
Indeed. I thought my chain was too long, had a conversation on text with someone "knowledgeable" said what's the guide for chain length on 1x (duh! use ChatGBT next time! (just tried it, it's answer was spot on)) - he said it was big ring big sprocket +2. I said, what same as 3X, this is 1X. He said yeah. Cost me a new chain that 😆
(Hardtail, btw)
Posted : 06/03/2023 12:15 pm
I wouldn't suggest setting it up with much less than the big ring at full compression but I'd happily go to the next link down but then I'm pretty mindful of it when cresting a hill and starting a descent so it's not been an issue.
Posted : 06/03/2023 12:32 pm
