Chain jumps/skips e...
[Closed] Chain jumps/skips even after replacing with cassette
Chain has been jumping/skipping on 2nd/3rd/4th cogs recently so I couldn't find anything wrong other than it being time to replace both chain and cassette. Have just put them on and exactly the same thing happens.
There are no kinks anywhere nor any reason why the chainrings could be causing some kind of kickback.
Hate messing around with rear mechs so I'm hoping this isn't a case of adjustment.
What do you lot reckon?
Ta
Posted : 29/06/2011 3:20 pm
Checked your mech hanger is straight?
Posted : 29/06/2011 3:21 pm
or rear mech itself
Posted : 29/06/2011 3:28 pm
Nope - mech and hangar totally fine.
Skipping happens even when not under loads. Chain doesn't seem to always want to sit properly on the cog.
Time for rear mech adjustment mayhem?
Posted : 29/06/2011 3:47 pm
set the mech up, if its still happening and you are convinced the mech and hanger is ok then chainrings might be next
Posted : 29/06/2011 4:27 pm
set the mech up properly ( or just randomly play with the barrel adjuster)
Posted : 29/06/2011 4:30 pm
Cogs 2 and 4 are now fine, but FFS no amount of rear mech adjustment is doing anything for 3. Chain just refuses to sit properly and skips up. Arse.
Posted : 29/06/2011 4:45 pm
Possibly the chain rings i had same problem. was fine on the top amd small chain ring, but as soon as i rode in the middle and was under pressure would skip
Posted : 29/06/2011 4:48 pm
Thinking about it, when I had a similar problen it turned out to be the cable inner binding in the outer and stopping it moving freely. New cables are seldom a bad move.
 P20
Are the jockey wheels ok?
Posted : 29/06/2011 4:49 pm
Play in the freehub?
Posted : 29/06/2011 4:54 pm
I had exactly the same issue on mine & i'd replaced the chainrings & set the indexing corrrectly too. The drivetrain was worn so that was the reason to replace it all, the skipping in 2/3/4/ & 5 was happening before the drivetrain replacement, & the damn thing was still happening afterwards. It would only happen though, when putting a lot of pressure through the pedals, i.e. going uphill, or having to plough through a techy section.
So, replaced the inner & outer cables, set the indexing perfectly & guess what??
It still did it! FFS!!
A further inspection revealed one tooth was broken off on the top jockey wheel. Fitted a spare & problem soLved!! ๐Ÿ™‚
So not saying that will cure yours, but worth checking the jockey wheels ime.
EDIT:P20 summed it up in one line!
Posted : 29/06/2011 5:01 pm
I had a similar problem to this and while it may not be the same cause I thought I should throw it out there.
My skipping was caused by the gear cable running to close to the bottom bracket, causing the cable to nip when the rear sus flexed, which in turn caused the gears to jump up the cassette and then back down as you stood up. If you've had new inners and outers fitted then this may be the cause.
Just my 2p ๐Ÿ˜€
Posted : 29/06/2011 5:30 pm
Hmm, more arse biscuits. Jockey wheels fine. Cables fine.
Tried another wheel (with new and old chain/cassette combos) and no skipping at all. But that wheel is properly buckled so not going to be using that as a short-term measure. And the Hope freehub is yonks old, but not causing a problem. And there's a fair amount of play too.
Put original wheel back on and the skipping reappears. Freehub seems okay and there's no play.
Doing my head in. LBS jobby methinks.
Posted : 01/07/2011 9:42 am
