Ok so i need some advice or a guide to chain guides.
I have a Transition Covert 27.5 it says it takes a ISCG 05 - 2.5mm Offset? Now i can work out the mounting part but the Offset confuses me.
I want a guide and Bash ring to suit my XT Double Chainset up front.
Im possibly missing some info or something.
No budget as such but best for the job?
Same as my bandit I run the E-13 trs+ its a great fit and forget.
Just stick the washers in between the guide & isg mounts. Blackspire twinty ftw!
+1 for E13 TRS+
The skid plate has some cracks after a years use, but still holding up.
My old setup was a Blackspire Stinger with E13 bashing. Worked perfectly.
Thanks, so the 2.5mm offset is covered by washers?
+1 also for E13 - if you want to stick with 2x. Loved mine before I went 1x.
Just steer clear of MRP and MRP rebranded stuff like SRAM's guides. Fragile, especially the 2x jockey guide system.
