Chain Device help n...
[Closed] Chain Device help needed...
ok, I've got a BB mounted Superstar plasma and I'm putting it on a Cove G spot.
73mm BB and Shimano Ht cranks. So I've removed the drive side spacer and put the chain device on. However when I put the cranks back on it fouls on the granny ring threads. Even if I file these off it will still foul the middle ring. I've got an e13 bash on the out side. how do I fix this? do I need longer cranks?
Posted : 23/06/2011 1:13 pm
Pictures would help.
Which bit is fouling the granny threads, the backplate of the device?
If shaved off you should have enough clearance to run a single ring ok, I have done so for before with a BB mounted chain device, stick some pics might help people see that exact issue.
Which cranks too, slx, xt?
Posted : 23/06/2011 1:26 pm
Yeah the backplate is fouling the granny ring threads. They are the cheap cranks M540 or something
Posted : 23/06/2011 1:54 pm
