Chain care - is it ...
[Closed] Chain care - is it just me?
...that doesn't treat my chain like a surgical instrument? Folk advising all sorts of different lubes, degreasing when new FFS?
I use Finish Line Wet lube, cos that's what I have in the cupboard, I rarely clean chains, just lube them when they sound rough. This "WORKS" for me.
Tests have shown a full degreased chain is as efficient as a lubed on!
Posted : 26/06/2012 7:53 pm
Please link to tests.
I use gear oil, because that what's the guys that make the chains say to use, it's made by a known and represented name in lubrication, and it's oodles and oodles cheaper than the boutique snake-oil on the market.
Posted : 26/06/2012 8:01 pm
Same here, regular squirt with wet lube, VERY occasionally remove and clean the chain in a bath of solvent. Mind you it's on a Rohloff so not so critical.
Posted : 26/06/2012 8:03 pm
Well, if it WORKS for you, that's fine. ๐Ÿ˜€
Posted : 26/06/2012 8:05 pm
Chainsaw chain oil is about the best you can get IME.
Posted : 26/06/2012 8:08 pm
Yep. Understood.
I do clean mine when I clean the bike but I just lube it with whatever I have lying around. Old fork oil, engine oil, free samples etc. It's not what you clean it with which matters, it's THAT you clean it that counts. I just give it a scrub with soapy water then lube. Any lube that's too sticky is a git to get off.
Posted : 26/06/2012 8:11 pm
I lube mine when I bother to wash it and that's it.
Posted : 26/06/2012 8:23 pm
I usually just spray with GT40 then run through a towel before dripping a bit of Dry lube on it.
however occasionally i'll take it off, drop it into a 500ml coke bottle with a splash of white spirit and give it a good shake, seems to clean it OK...
Posted : 26/06/2012 8:25 pm
Purple extreme. Less chance of chain suck (carbon frame)) than with crapped up chain.
Posted : 26/06/2012 8:27 pm
I'm not that fussed really.
Finish Line Wet for most riding (it's Scotland). I also have some Finish Line Dry for "best" and a lovely ceramic stuff which I use on the road bike. I like the latter as it seems to stick to the chain really well without attracting lots of road dirt.
I will, very occasionally, do a full chain clean using one of the those whirly machines, but usually I can't be arsed.
TBH, I seem to be a lot less precious about my bikes than I was. Once upon a time they would get a good hose down/wash/re-lube after almost every ride. Now I have to be in the mood and they have to be pretty filthy before I'll do it.
Posted : 26/06/2012 8:31 pm
