I've got the 1200lm C&B Seen lamp for mounting on my bars and it's great, except I find that it spins backwards on the bars over rough ground. It's the typical rubber band method of fixing that's the problem. I've tried tape on the bars, which did nothing, so now I want an actual clamp.
Found this Hope universal clamp, which might work. Looks a bit crappy and plastic though.
[url= http://www.chainreactioncycles.com/hope-universal-handlebar-mount/rp-prod23533 ]Clicky[/url]
Anyone used it, or another derivative that works well/better?
Ta
I've used one of those on a light. It is a bit plasticy but they work.
Cheers, which light? Is there just a hole in the flat bit of the clamp to fit a bolt through?
I use one of those too. on the 1200lm C and B see light.
Just unscrew the little plastic bracket and screw on the hope one. Works a treat.
All the chinese lights have a very similar mounting. You can swap them out for better mountings really easily.
I use an old cateye mount for the Solar Storm light on my helmet
