Casette spacers for...
[Closed] Casette spacers for pro4 boost hubs
Hi All
Got a pro4 boost hub with a 10 speed cassette on it currently. Just in the process of swapping to an 11 speed one.
As i understand even though hope use an 11 speed body you still need a spacer at the back.
Should i use the same one from the 10 speed.
Only reason i ask is that i'm not convinced i have that much thread of the lock ring in the hub body once the old spacer is in and its done up tight (cassette rings seem tight though)
Pat
Posted : 17/05/2017 1:25 pm
9sp, 10sp and 11sp are the same size when considering MTB cassette widths on the freehub body. The spacer should only be removed if you're using a road cassette.
Posted : 17/05/2017 1:28 pm
so same spacer it is then!
Thanks, good info ๐Ÿ™‚
Posted : 17/05/2017 1:52 pm
The label on the bag containing the spacer that came with my Hope 4 Boost hub reads as follows:
"Use this spacer when fitting a 9/10 speed cassette or XT-M8000/XTR-M9000 (11 speed) Cassette"
Posted : 17/05/2017 1:54 pm
I guess they printed those labels before the SLX-M7000 cassette was released. I tried leaving it off when I fitted mine, but it definitely needs it ๐Ÿ˜ณ
Posted : 17/05/2017 1:57 pm
nice! Thanks
(erm hopefully the spacer that was already behind my old cassette is the right one - i'm going to assume so and press onwards)
Posted : 17/05/2017 1:58 pm
