Can this be used with Hollowtech 2 bottom bracket? It doesn't look as if there is room in a "standard" BB shell.
Tom
Posted : 02/04/2009 5:42 pm
Tom, the Carver EBB is compatible with any english thread BB available, so yes, a HT2 works fine.
Posted : 02/04/2009 6:15 pm
Thanks Trev, I assume there is limited adjustment but enough to take up the slack.
Tom
Posted : 02/04/2009 6:42 pm
are you running it at the correct torque? 75-80 inch pounds or you could over tighten, and then you will be stuck............
Posted : 02/04/2009 8:58 pm
Sounds like Tom is thinking of trying to fit a Carver EBB into a standard BB shell?
If so it won't fit.
It will fit in most EBB shells and take a HT2 crank though.
Posted : 02/04/2009 9:06 pm
๐ณ SSstu, you are correct and I have now learned the error of my ways. Thanks guys, most helpful and my apologies!
Tom
Posted : 02/04/2009 9:14 pm
