Carbon Soled Shoes
[Closed] Carbon Soled Shoes
I recently purchased some shoes with a carbon sole. I was careful when fitting the cleats and nipped them up nice and tight but not to hard. I thought the cleats would then bed in before I nipped them up again.
Last Wednesday night I noticed that the inside of my shoe was catching my crankarm which I thought was strange. Again, on todays ride it was happening again as well as me knocking my heel on the swingarm.
So I stopped and checked the pedal and then my shoe. The cleat had come loose and its movement has badly marked/idented my sole. I nipped it up again a lot tighter but once the ride had finished I noticed the cleat had slightly moved again.
Is there anything I can put on the sole as a foundation for the cleat and to fill the mark/ident created by the movement? Is there anything I can do from stopping this in the future?
Posted : 01/03/2009 5:51 pm
A wee splash of locktite never did any harm...
Posted : 01/03/2009 5:56 pm
I just use grease on the bolts and do them up nice and tight. I've never had them move on several pairs of shimano carbon-soled shoes.
Posted : 01/03/2009 5:58 pm
Thanks fellas. I greased the bolts the last time so I may use a drop of loctite this time round. Just concerned that the cleat will try and revert back to position where it slid and dug itself into.
Posted : 01/03/2009 6:12 pm
crank bros do some shims that fit under the cleat, as eggbeaters are hard on shoes, so they would probably work for you
Posted : 01/03/2009 6:24 pm
