What setting should I use on the stem bolts?
Posted : 09/08/2009 9:47 am
same torque you would had you alloy bars ....
Ie my thomson stem says torque to 4Nm ... so i have my carbon bars torqued to 4Nm - any less they will probably slip , any more and ill crush the bars or split the faceplate
Posted : 09/08/2009 10:29 am
I have always found that 4nm is enough if you use Ritchey liquid torque. Otherwise I have had slippage at 5+nm (therefore bottom line is that the Liquid torque gel is invaluable)
Posted : 09/08/2009 10:35 am
yeah i use finish line carbon assembly paste - it has them little friction grit particles in
Posted : 09/08/2009 10:45 am
