Carbon Assembly Pas...
[Closed] Carbon Assembly Paste - same as anti-sieze?
 5lab
[#2305530]
Hello
I've got a dropper seatpost, and I'm having some difficulty getting the seat collar tight enough to grip the post, without the post distorting and affecting the 'dropping' performance.
Now, it seems a similar problem is had by those with carbon seatposts, so you can get carbon assembly grease which is used to help the bits grip. I've 2 questions :
will this stuff work between a steel frame and alu post (or does it do something fancy to the carbon itself)
is it any different from standard anti-sieze grease?
Thanks!
Hugh
Posted : 22/12/2010 12:33 pm
Yes it is different... carbon paste is like clear grease with added bite. Almost like a sand added to it. Helps the two grip together.
Posted : 22/12/2010 12:39 pm
It will be fine between a steel frame and alu post. I use it between Ti-alu for the same purpose. Its magic stuff!
Posted : 22/12/2010 2:25 pm
 5lab
cheers guys. Pace RC003 ordered 🙂
Posted : 22/12/2010 2:26 pm
