Capra (Mark II) bea...
[Closed] Capra (Mark II) bearing change
Plan to service the bearings soon after neglecting a couple of years.
One of the YT clip for Jessy uses a blind bearing extractor for the main pivot. There is one more seatstay bearing for Capra and I haven't been able to work out from the expansion diagram whether that needs the blind extractor too (i.e. if both bearing on the upper stay).
Would I need something similar? Amazon has some YT related tool set https://www.amazon.co.uk/BearingProTools-Bearing-Puller-Bike-Frame/dp/B07K8SFF11?th=1, but I guess some general blind puller would work too.
Thank in advance.
Posted : 21/12/2021 12:12 am
You can get a full kit of blind bearing ullers for bout £35, including the slide tool.
This is what I have
https://www.amazon.co.uk/YUAN-Bearing-Puller-Remover-Internal/dp/B07DXKRB4V/ref=sr_1_11?crid=YWF0LE4BH6O5&keywords=bearing+puller&qid=1640097448&sprefix=bearing+puller%2Caps%2C109&sr=8-11
Posted : 21/12/2021 3:38 pm
Nice one, tried to minimise too many tools but look like can't avoid this.
Thanks.
Posted : 21/12/2021 8:13 pm
