Canyon spectral wit...
[Closed] Canyon spectral with 160mm fork
My spectral came with pikes set at 150mm. I was thinking about upping them to 160mm. Has anyone already done it? How did you find it?
Posted : 13/11/2015 12:16 pm
My Spectral came with 130mm Fox 32s, and I replaced with 150mm Pikes, I haven't died yet.
Posted : 13/11/2015 1:01 pm
it was death I was cornered with. I know the frame will take it as it's only 10mm up from where I'm at. I was more interested to find if people noticed a difference due to change in geometry
Posted : 13/11/2015 1:58 pm
I cannot comment on the Spectral, but on my old NP mega 10mm made a huge difference.
170mm = great!
180mm = flip floppy horror show!
HTH?
Posted : 13/11/2015 2:18 pm
I've this years spectral with a Pike. Are you able to adjust the travel on them? I'd be interested to see how you get on.
I'm having fun trying to get the CCDB inline worked out. Think I might end up having to read the manual.
Posted : 13/11/2015 2:34 pm
for changing the forks
I have inline and I'm still on the base setting. everytime I change it the feel isn't the same. suppose that's the point of the base setting
Posted : 13/11/2015 2:43 pm
I found when I was out in the alps (trans provence) I was bobbing a lot on the climbs. I kept the base and put in more air so there was less sag than recommended. Then i started fiddling.... might have to go back to base and be more careful.
Cheers for link.
Posted : 13/11/2015 6:20 pm
