Canti's on my Pompi...
[Closed] Canti's on my Pompino rear end - how?
Evening all,
Finally gonna build up the pomp for its comuting and general road purposes. I have a set of canti's to go on it. Front end is no problem as I have a cable stop/headset spacer. Rear end is gonna prove tricky though. I've got a neat little bit that can be bolted onto the frame:
But there's nowhere to bolt this on on the wishbone stays.
Any ideas?
Cheers.
jon
Posted : 05/07/2009 10:41 pm
Rear Cable Hanger For Cantis
http://www.on-one-shop.co.uk/cgi-bin/sh000001.pl?REFPAGE=http%3a%2f%2fwww.on-one-shop.co.uk%2f&WD=hanger%20canti&PN=Online_Catalogue_Hangers_351.html%23aBSRCH#aBSRCH
Its a hanger that fits on the seat collar bolt between the pinch flanges of the seat tube opening.
Posted : 05/07/2009 10:48 pm
That'll do it. Nice one. Ta very much.
Posted : 05/07/2009 10:53 pm
Quick update and PSA.
Just taken delivery of a new white 120mm pompino for a mate.
I ordered the canti hangers (front and back) from OnOne.
The new frames come with a new frame canti hanger fitting
so the extra one I ordered is surplus to requirement.
The front one fits on the steerer.
Posted : 20/07/2009 1:01 pm
Hello is that 1992? This is 2009 calling....
Posted : 20/07/2009 1:09 pm
Cheers for the update. I ended up using a Surly hanger. After trying a number of clamps I finally found that the on-one clamps have enough of a gap between them to do up tight enough before they clamp the clamp.
Posted : 20/07/2009 1:11 pm
like this GMJ?
[img] http://ep.yimg.com/ca/I/yhst-84224226242177_2058_17772439 [/img]
Posted : 20/07/2009 1:13 pm
Stoner - it used to be the case that the larger sized pomps had a canti hanger welded on, while the smaller ones didnt. Might be useful for others to mention what size your is?
Posted : 20/07/2009 1:16 pm
the white one is a large.
just out to the shed to photo mine/Mrs
EDIT: Right, this one is my Xtra Large 120mm pomp - 2006 in blue
Both need hangers fitting
and Mrs S Small '06
Posted : 20/07/2009 1:19 pm
Odd, my blue pomp XL came with a welded hanger. Must be a 'rolling improvement plan' ๐Ÿ˜†
While ive got you stoner, what gear ratio do you use on yours usually? (an on your epic trip!)
Posted : 20/07/2009 1:33 pm
Epic trip was 49:20 free (67")
Currently 49:18 free for going to the pub or down to my parents (c.10 mile trips around Malverns - a few sharp hills), occasionally 49:18 fixed. (73")
Have just fitted a 16 fixed to it to have a go at improving a poor local TT time I did the other day (82")
EDIT: our Pomps w bought as full bikes - I dont think they did many of them and Im guessing they used a different frame batch as the bikes were assembled out East I think then shipped in.
Posted : 20/07/2009 1:36 pm
67"? Yikes!
I can just manage 70" on moderatley hilly stuff but bail to under 60" when fully loaded. Respect to MrsStoner!
Posted : 20/07/2009 2:07 pm
guitarmanjon, in your first post you have a pic of a brake hanger. Where did you get it from? I have wanted one for ages but cannot find one anywhere.
Thanks,
Adam
Posted : 20/07/2009 6:43 pm
adam - picture URL comes from fisheroutdoor.
Posted : 20/07/2009 10:44 pm
