Have just switched from Zwift to Rouvy for a change.ย Can get it all to work easily enough on my android, but when I login into laptop I cannot get the app to pick up the smart trainer.ย I have windows 11 laptop with necessary specs.ย Have turned off blue tooth on phone to avoid pairing with that - but I cannot get laptop to pick up the trainer at all.ย Would like to run from laptop to connect to bigger screen.ย Any advice.ย ย Zwift ran just fine fyi.
Haveย you tried using a USB ANT stick and have you recently updated the firmware on your trainer?
ย
ย
I had to buy an ANT+ USB stick in order to use my laptop with Rouvy. (Had previously used an iPhone and that had ANT+ connectivity, but my old Windows 10 laptop doesn't have it built in).
I run Rouvy on a Windows 10 surface pro and connect to my Wattbike Atom via Bluetooth. No ANT+ required. What trainer do you have ?ย
As above, when got new laptop with W11 had same issue. Got Ant+ dongle and updated drivers.
Was another thread on it not so long ago.
I have W11 with wahoo kickr core trainer - the rouvy app does not pick up the HR either
ย
my android phone works with the app and connects to everything instantly, which I reverted to yesterday after spending over 2 hrs trying to get laptop to work!
