Hi all,
I have just go hold of a Cannnondale Scalpel frame and am in the process of building it up.
A few things are giving me headaches, the biggest of which is that the chain rubbing the top of the chainstay when in the smallest cog. Surely this can't be right?
I can only think a bigger front ring might help raise the chain a little but it would be daft if a 34T ring is the smallest that can be run- what about the Hollowgram doubles with smaller rings, how does the chain not rub the chainstay then?
I am sure there is a simple solution I am missing! Can anyone help please?
Thank in advance, DanW ๐
[u]P.S. Extra info:[/u]
32T single front ring
Rotor 3D (triple cranks running the single ring in the middle ring position)
Cannondale bearings
Wheelsmfg BB30 to 24mm adapters
Xt/ XTR 11-36 10 speed cassette
I ride a 2011 Scalpel with XX rear mech and 36 front ring an a 1x10.
When in the 11t on the cassette, the chain is a few mm above the chain-stay. The gap increases when you sit on the bike due to the flexy stays.
I don't run a clutch mech so occasionally I get a little chain rub on the say - a neoprene stay cover prevented this from causing damage.
It wont rub when your weight is compressing the rear end of the bike.
Fair enough, I thought I must be missing something obvious!
Next problem is trying to get the chain line/ crank spacing correct. With the Rotor cranks fitted as per the instructions (with rgards to the spacers used) the 32T front ring is only a mm or so from the metal chainsuck plate and the chainguide rubs the inside of the chain. I have had to swap the Rotor spacers around so the DS has the thicker spacer to set the DS crank further out and away from the frame. Hmm....
