What's your weight and what pressure are you using in the shock, I'm 14st running 180 - 190 psi as per the manual and struggling to reach full travel.
Posted : 02/02/2009 10:21 am
How much sag are you running?
Set the pressure to correspond to the 25-30% sag, ignore the manual.
Not that I own a rush, but this is the usual guide for Single pivot bikes. 😀
Posted : 02/02/2009 12:26 pm
Why run what the manual says? The manual doesn't know how you ride.
Set it as is best for you. Try a bit lower and see how you go.
p.s. The standard shocks on the rush have an internal bumper fitted to limit stroke to 45mm (not the normal 50mm for a 190mm length shock), so you might actually be getting full travel if you were expecting a 50mm stroke.
Posted : 02/02/2009 1:08 pm
