Cane Creek Double B...
[Closed] Cane Creek Double Barrel Airs - does a mm make a huge difference?
Looking at buying a new frame with a shock size of 215 x 63mm. A mate's selling a CC DB Air which is 216 x 63mm. The frame I'm buying has previously been sold with a CC DB Air as an option. What's strange is I can't find the 216 x 63mm to buy aftermarket, only 215 x 63mm.
I am wondering whether that whole mm is an issue, or whether it's actually a slight misinterpretation when converting from inches (215.9mm).
So, basically, if I buy and run this, will I die?
Posted : 12/04/2016 9:34 am
That's just rounding. 8.5" is 215.9cm - this is why Rock Shox have gone al metric
There is of course a very good chance that if you bottom out without rounding down the extra mm will go into meltdown and explode.
Posted : 12/04/2016 9:48 am
This is what I am afraid of... ๐Ÿ˜†
Posted : 12/04/2016 9:56 am
I've got a banshee rune, and tried Verious rockshox debonair and now a CCDB air
It seems to depend on the web site it they round up or down 216/215mm but don't stress it's all the same.
In my humble opinion, after years of fox rp23 and then rockshox monarch then debonair piggy back the CCDB air is a different level of quality, bit heavy but amazing when set up, made my pikes up front feel wooden.
Posted : 12/04/2016 10:17 am
Cool, thanks. That's the conclusion I've leapt to, and shock is now mine. I look forward to finding out how much better it is than the Fox CTD it's replacing.
Posted : 12/04/2016 3:14 pm
seeing as offset bushings get sold aftermarket, which effectively change shock length by up to 6mm, you could either
(1) buy some yourself to undo the extra mm, or
(2) take that as a sign that being a mm off is acceptable
Posted : 12/04/2016 3:19 pm
