Cane creek DB IL po...
[Closed] Cane creek DB IL possibly leaking seal
Put air in my DB IL shock this afternoon. Its on a 2016 Banshee Spitfire frame. Shock was sitting at just under 140psi so I wanted to top it up as im about 85kg and the sag was about 45-50% at current pressure. I pumped it up to 160psi and removed the shock pump. I put the shock pump back on to double check the pressure and it had dropped to 125 psi. Tried to raise the pressure a few times but it doesnt seem to want to stay about 130ish psi.
Time for it to be serviced?
Any help would be great. Cheers
Posted : 04/05/2019 6:31 pm
If you cannot get the correct sag then yes, it seems like the shock is leaking.
Do keep in mind that the pump will always show a lower reading due to the fact that the hose and the gauge will fill up with air from the shock when you connect it.
Posted : 04/05/2019 7:01 pm
Sounds like this is what you're seeing. Does the sag increase over a couple of weeks if you're not attaching a pump to check all the time? ๐Ÿ™‚ If not, no issue.
Posted : 04/05/2019 7:17 pm
Could be the hose and shock filling up with air by the sounds of it. I did try and pump the shock up beyond 150psi earlier but it didnt seem to make any difference to the sag,stayed at about 45-50%. I didnt want to pump it up too much incase the pump wasnt giving a true reading and I blew the shock up.
Posted : 04/05/2019 10:20 pm
