Nope, vertical dropouts can be used.
Hi psychle,
alpine in a whyte - that just what I'm about to do.
Did your alfine come already built as a wheel or did you build it yourself? (what rim are you using?)
Just about to order rim, spokes etc - not sure what sizes I need.
ps AFAIK - perfect the way you've got it - just adjust dropout to take up chain slack.
Howdy MLC 🙂
My Whyte is an older 19 (an '07 I think), bought it off here 2nd hand. Same with the Alfine actually, though it came on an inbred I bought last year (again off here) I think the rims are On-one Retards, though have never been able to 100% confirm this. Can't help with the spoke length info etc, sorry 🙁
cheers for the confirmation that vertical dropouts are cool... had a bit of a brief worry about it before, hence the post to get reassurance from the STW hive mind 😆
The fitting kit comes with different coloured tabbed washers to hold the hub in place for the cable. One colour for horizontal, one colour for vertical. Just make sure you use the right one.
hmmm... I only have one set of tabbed washers (the ones that came on the wheel when I bought it off here). The left one is blue, the right one is green.
You have the washers for vertical dropouts. I have an alfine on a p7, it's fine so far.
Which colour washers are for vertical dropouts? Also, what should be the orientation of the cable entry point on the hub?
I have got a barely used Alfine chain tensioner £10 posted, you will need some form of tensioner.
Tom
Err, blue is R, green is L for vertical dropouts. Cable entry point is towards the BB, i.e the cable is routed along the chainstay.
Not with sliding dropouts he wont!
yep, don't need a tensioner thankfully, one of the benefits of the Whyte 19 frame 😀
Tom
Mine are back to front then... might explain why the cable entry is pointing upwards 😆
Does the cable have to be routed along the chainstay? You can't orientate it so as to use the seatstay?
if you look on sheldon browns website he has a chart you can use as there are more than just one of the vertical drop out options depending upon the angle of the drop out, just make sure you do the non turn washer up nice and tight as i once had my pull out on a big steep up the hill out the saddle episode and it wasn't fun.........
You could route it the other way, but you'd have the pulley stuck out the back of the dropouts, bit vulnerable really. I accidentally put the hub in like that, but realised and moved it 180 round. If you look at all the Alfine bikes on the net they're like that, cable routing is so much neater.
I bought some adhesive cable guides from CRC. Not put them on yet, so cable goes along top and seat tubes then underneath the chainstay currently. Mainly because I had the hub on backwards when I started routing the cable 😳
I have it here in front of me. The only washers for vertical dropouts are the blue and green ones.
can you use a grip shift with the alfine hub?
You can use a Nexus gripshift, I believe....
That's what I use - spazzy thumb and all that.
I'm thinking of the Versa STI shifters for my project
My cable comes straight out the top of my alfine and up the seatstays. Fiddled around with the combinations of washers I got to make it work. Can't remember what colours I used though.
Them Versa STI shifters do look nice. I don't understand why shimano haven't produced one though. 🙄
thanks, off to google nexus
Geoffj or Druidh, where can I find info on Versa shifter? Tried Google but only found one reference.
Tom
Mine are back to front then... might explain why the cable entry is pointing upwardsDoes the cable have to be routed along the chainstay? You can't orientate it so as to use the seatstay?
You can route the cable wherever you want, its just easier to use the chainstay as the cable exit on the hub is horizontal (if you run the spacers the right way round). You could just leave your spacers how they are and have the cable exit vertically and fix the cable to the seatstay, wouldnt casue any damage to the hub.
Tom - I am waiting to hear from the US as to whether or not there is a UK importer. I will pass on my findings.
By swapping the axle stops from side to side or turning them around in increments you can position the guide arm 45deg at a time. Luck if you get it spot on. Mates Inbred lines up perfect, but my Explosif is not right but fine.
I had a long argument with someone on here about this 🙄
