As in the funnel bit. Does anyone know if the threaded section is the same so I can utalize my Hope bleed kit rather than buy a shimano one. I've a number of big syringes for measuring out epoxy but its the funnel bit that would be nice if its all the same
Or am I just being a cheapo.
I'd be worried about cross contamination of the different fluids. They really don't play well with others system. For £4 I'd buy a dedicated funnel.
As above I would be worried about cross contamination. Our Shimano bleed kit and SRAM bleed kit are kept in separate drawers to ensure this can't happen.
For what they cost its not worth the risk
I acquired a spare Shimano one but gave it away at a race when someone had forgotten theirs. It's one piece of kit I won't lend out as it could turn into an expensive favour
Some one one here may have one they no longer need
I'm el cheapo,I just use a reverb syringe with plunger removed - screws into lever nicely.Then I pop the plunger back in when finished to stop oil escaping on removal.
If you’re worried about cross contamination surely you could just clean the funnel with some spray brake cleaner and dry with paper towel to remove residue of the “last” fluid?
keep totally separate kits for each. Why would you do anything else?
I’d be worried about cross contamination of the different fluids. They really don’t play well with others system. For £4 I’d buy a dedicated funnel.
Ahh, i was under the impression it was a kit for £25. I'll look again and pick something up. As to cross contamination, the hope one is metal and easy to clean, Were it possible I dont think that would become an issue.
I use the same syringes for Shimano and Hope/Sram bleeding
Just clean out the syringe and hose after every use and you will have no problem, been doing this for years and have had zero issues
It'll fit the shimano port fine, used mine on one recently as the threads on the plastic shimano ones eventually wear out. Just make sure you clean it properly after use, as if the o-rings are the same material as their brake seals, you'll end up with them turning to chewing gum.
Yeah, I think the contamination thing is slightly exaggerated, if you clean it, it'll be fine. In an emergency, I'd do that without worrying about it but I have separate kits for mineral oil and DOT brakes. For the minimal cost of a bleed kit, it's much simpler to have two kits. Also, in an emergency, you can generally just use a plastic squeeze bottle an bit of hose on the bleeder on the caliper.
Some mechanics use the Hope cup with an o ring change on Shimano as the cup is more durable.
I would say slightly more care is needed with the metal cup, with the plastic cup if you damage the threads its going to be the plastic cup, not the brake lever.
The new Shimano bleed cup also has a partial lid ring which is handy for more extreme angles without spilling.
Blimey! How many times are you bleeding your brakes to find that out?!
Not my brakes, wouldn't have 'em if you paid me :). Do hell of a lot in work, so they don't last more than a couple of months,made my own on the lathe for work, bought a Hope for home use when they came out.
So are people with seperate kits not cleaning out their syringes etc after bleeding or do they believe hot soapy water following by a squirt of muc-off cleaner isn't enough to avoid contamination, maybe they have seperate teaspoons for their coffee and yoghurt 😀
Anyway it's good to know the threads are the same, so basically Hope users can just buy the £7 special mc cap and use a shimano funnel instead of buying a full Hope kit.
I wipe them and stick them back in their separate boxes. It’s not that I don’t believe you can clean them (though I’d have my concerns about any seals/O rings) more that I couldn’t be bothered with all the cleaning
Thanks for the info @Bigyan.
I'll probably go with just getting a kit on info, especially if theres a possibility of damaging threads. The hope screws first into a brake specific cover so you cant mess that up, but part of the brake, i wouldnt like to risk it for the sake of a fiver part
