Can you shim a 1.5&...
[Closed] Can you shim a 1.5" stem to 1 1/8th?
I foolishly bid on the wrong wtem off ebay and now have a 1.5" stem lying around unused. I could use it on another bike- can you get reducer shims for this?
Posted : 13/08/2015 2:08 pm
The reducer shims for a 1-18" to 1" steerer shims would also work for this I assume, just need to be opened up a bit to stretch onto the larger steerer... though that does sound potentially dodgy... maybe someone nice on here will machine one for you?
Posted : 13/08/2015 2:36 pm
I'm no engineer but surely that would just reduce an 1 1/4" stem to 1 1/8", not a 1 1/2"?
Posted : 13/08/2015 3:04 pm
Me neither - good point... ๐Ÿ˜†
Posted : 13/08/2015 3:09 pm
Yep, I did the same thing and had to make a sleeve to reduce an 1 1/4" stem down to 1 1/8". It works fine as long as you put a slit in the sleeve that lines up with the slit in the stem so it can tighten up.
Can't you return the part?
Posted : 13/08/2015 3:38 pm
