Can you retap a cra...
[Closed] Can you retap a crank arm.
Stripped the thread on my left hand SLX crank arm anybody know if I can get it sorted.
Posted : 22/02/2010 10:25 pm
which ones? on the pinch bolts? Should be possible to have a threaded insert or helicoil fitted
Posted : 22/02/2010 10:27 pm
Pedal threads
Posted : 22/02/2010 10:33 pm
Pedal threads are an odd size so not as easy to find someone with the correct insert but it can be done. Ask your LBS
Posted : 22/02/2010 10:40 pm
 nonk
again a helicoil might be a goer depends how mashed it is.
sometime you can sort it by running the pedal in from the back of the crank if its just a bit chewed.
Posted : 22/02/2010 10:41 pm
Yes they can, well not retapped, but repaired. We'ver got special pedal taps that cut out the old damaged threads & cut a new one for an insert, which is then wound in the same as a helicoil back to the original 9/16" size
Posted : 22/02/2010 10:42 pm
Will drop it down LBS , cheers
Posted : 22/02/2010 11:07 pm
