Can you recommend a...
[Closed] Can you recommend any strong patches?
[#9596086]
Hi sadly when converting to tubless for the first time I noticed a split in my used rear tyre.
I want to repair the split so was wondering if anyone has any recommendations kn good long lasting patches?
Posted : 09/10/2017 1:48 am
http://www.chainreactioncycles.com/sg/en/velox-tubeless-repair-kit/rp-prod40010
I actually wanted to buy this but its not in stock and i cant find another stocker of it in the UK online.
Posted : 09/10/2017 7:46 am
How big is the split? I use automotive plug patches from eBay. 4 or 6mm depending on the side of the hole.
Posted : 09/10/2017 7:48 am
Car/motorbike tyre repair patches - plenty on ebay
Posted : 09/10/2017 7:50 am
I've had several successes with ordinary tube repair patches, assuming the hole is relatively small. Even with slightly larger holes a patch on the inside and a dab of liquisole on the outside can work.
Posted : 09/10/2017 8:31 am
[url= https://www.amazon.co.uk/dp/B001C6BKDC/ref=pe_3187911_185740111_TE_item ]Hutchinson repair kit[/url]
I got the larger (MTB) version which worked well for the one I used first.
Bit pricey for 4 patches mind.
Posted : 09/10/2017 9:05 am
It's about 3 mm id say, not the smallest but seen bigger
Posted : 09/10/2017 11:52 am
Posted : 09/10/2017 11:53 am
Stu is spot on, that's the absolute best repair ime.
Posted : 09/10/2017 12:21 pm
Use this.
http://www.ebay.co.uk/itm/Xtra-Seal-Vulcanizing-Cement-Tyre-Repair-Fluid-235ml-Tin-With-Brush-/130779078553?hash=item1e730a5f99
To stick these on.
http://www.ebay.co.uk/itm/12-TYRE-PUNCTURE-REPAIR-WIRED-3MM-SMALL-HEAD-PLUG-PATCH-MUSHROOM-/131208504777?hash=item1e8ca2e5c9
I think ill order these look promising. Does the spray just go on the outside of the tyre? Does it fill the split kind of thing.
Also do i just insert the plug normally like a patch then just cut the excess from the outside of the tyre? Cant seem to find a video on a repair using these products.
Posted : 11/10/2017 1:17 pm
Hi i took yours and stus advice and bought this and its arrived today.
I was just wondering if you could give me a run down on how to do repair the split using this method before i have a go myself.
Thanks a lot.
Posted : 14/10/2017 2:14 pm
Sugru?
Posted : 14/10/2017 2:15 pm
This should give you an idea but no need to use an air sander for mob tyres.
https://m.youtube.com/watch?v=mflq7WD0V6o
Posted : 14/10/2017 2:59 pm
Yeah, that vid is spot on. You probably won't want to drill an mtb tyre but sometimes I'll cut or nibble the hole just to give it a round centre- our tyres tend to slice rather than hole, and you really want a hole the size of the stalk/flappy bit for it to go through.
I like to slightly reinflate with a tube in, just to really mash it into place and make sure it's going to keep shape nicely. Not too much as it might pull the cut open before the glue sets
Posted : 14/10/2017 3:06 pm
Thanks man made it much clearer thanks mate.
Posted : 14/10/2017 5:15 pm
Thanks mate i amd going to have a go now,this will also be very handy for my motorbikes in the future aswell.
This methord looks much better than normal patching and sewing the split.
I will keep the thread updated 🙂
Posted : 14/10/2017 5:17 pm
I'm trying to remember the Patches that Clarence Carter depended on.
Posted : 14/10/2017 5:56 pm
Just bookmarking for later.Cheers.
Posted : 14/10/2017 6:39 pm
I find it best to turn the tyre inside out when using the mushrooms and pulling them through with pliers to get a good fit around the hole. Once it's dry turn it back and refit it.
Posted : 14/10/2017 9:53 pm
Worked perfectly now just to see if it holds. The type of split mine is the plug was a little loose but i made a little circle hole in it as advised and the sealent easily filled the rest.
Thanks for recommending this repair method to those who did, very easy to do, in many ways and looks like it will last.actually easier than sticking a regular patch on!
Cheers for saving me 30 quid in hard times.
Posted : 14/10/2017 9:56 pm
Yeah i actually figured that out for my self, i turned it inside out and let it rest for ten minute's and let the tyyre repair stuff do its thing. Stuck a tube in left it for another ten minute's and jobs a good n.
Posted : 14/10/2017 9:59 pm
