Can you re-thread a...
[Closed] Can you re-thread a bb ???
Thought id ask as one of mine is a bit of a mess..
Posted : 27/07/2009 3:03 pm
 mos
yes, decent shop should have a thread chasing tool, easy diy job, but not a diy tool (quite expensive)
Posted : 27/07/2009 3:07 pm
Agree with mos, plus if the shop screws it up its their fault!
Posted : 27/07/2009 3:12 pm
If that fails you might be able to get a steel sleeve fitted, oooooor if youre using square taper cranks you can buy a BB that threads onto itself instead of the frame ๐Ÿ˜€ charlie the bike monger sells em.
Posted : 27/07/2009 3:15 pm
 jond
>steel sleeve fitted
I *think* it's Argos that will do that.
Dunno what number you need to take to the checkout tho' ๐Ÿ˜›
Posted : 27/07/2009 4:29 pm
Not always, depends how borked it is. If it's steel they can cut & weld it though.
Posted : 27/07/2009 4:34 pm
I messed up the thread on mine when changing the bb. Thought it was a write off but took it to my lbs. Within an hour they had it re threaded and my bb fitted.
Posted : 27/07/2009 6:31 pm
Gona go to the lbs tommorrow.
I trust him..
cheers
Posted : 27/07/2009 7:29 pm
