Can you get anglese...
[Closed] Can you get anglesets for cx bikes?
Google seems to say need a tapered steerer but I thought I'd check at the fount of all knowledge 😂
I want to steepen the HA by a small amount, as I prefer the sharper handling of my old bike with more trad geo to my current bike with a 70deg HA. I'm going to try removing a spacer first to see if a bit more weight over the front improves things first but would be interesting to experiment with HA if possible
Posted : 16/01/2020 8:20 am
bump for lunch... humour me, last week I couldn't ride due to an infected toe, now I have manflu, the only thing keeping me sane is overthinking minor problems ๐Ÿ™‚
Posted : 16/01/2020 12:50 pm
What headset does it have? integrated or external?
If its a an external ec34 1 1/8 like everyone used to run in the good old days then this guy makes a 1.5 degree one, or could probably custom make you any angle you want.
https://www.pinkbike.com/buysell/2185738/
Posted : 16/01/2020 12:52 pm
Run 35c rear, 28c front. Cant think of a single reason not to
Posted : 16/01/2020 12:57 pm
@wzzzz - nah integrated, I think I'm on a hiding to nothing tbh.
@mashr - interesting idea but tyre availability and maybe UCI rules mean that's a no-go
Posted : 16/01/2020 1:07 pm
Non-teper 1 1/8"
https://www.superstarcomponents.com/en/slackerizer-angle-headset.htm
2 degrees should make it mroe fun. Putting more weight over the front will make it more stable not less. You'd want a shorter stem for faster handling.
EDIT integrted headset - you'd have to file it out I guess, maybe the crown races of the above will get you there, as there isn't a lot of load on the top races.
Posted : 16/01/2020 5:21 pm
Check Works Components, they do lots of options;
https://www.workscomponents.co.uk/
Posted : 17/01/2020 4:01 pm
