Can you convert RS ...
[Closed] Can you convert RS Revs Dual Air to U-turn??
 LMT
Just as the topic title is!
I have some RS Revs the 09 ones which ive already added the spacer to lower the travel to 125mm but today on the trail i needed less travel for some tight corners and other parts of the trail my 125mm was just a bit too much.
So can the forks be converted?? and where can i get the parts from??
Posted : 13/09/2009 6:41 pm
Talk to TF Tuned Shox, if it's possible, they'll know and they'll be able to get you the parts. It might not make economic sense though, depends how much the Air U-Turn parts cost, I guess.
Posted : 13/09/2009 6:48 pm
BWD is on the right track, but having had both u-turn and non u-turn forks apart, I seem to remember that the inside of the stanchions is different, menaing you'd need new uppers and also new spring internals (Damping will probably be the same) In essence, you'd have to replace 60-70% of the fork.
Personally, I'd say selling them and get new/used u-turn forks to replace them will be cheaper, easier and faster.
Happy to be proven wrong though!
๐Ÿ™‚
Posted : 13/09/2009 7:02 pm
