can you check my ma...
[Closed] can you check my maths before I order a reverb?
Current seatpost at highest is 240mm from seat collar to saddle rails
my frame has minimum 4 inches (100mm) of insertion, but I like to run a little more.
frame is only reamed to 8 inches (200mm), but I reckon this is more like 180mm when measuring with current seatpost.
So minimum post size would be 240mm + 100mm = 340mm
Max post size would be 240mm + 180mm = 420mm
So looks like I could get away with either a 355, 380 or a 420mm reverb?
380mm looks the best option I think? giving me 140mm (5-1/2inches) of insertion?
Posted : 11/08/2012 9:20 am
Minimum exposed seat post is 190mm from bottom of collar to seat rails. With a normal seat post height of 240mm you'll have 140mm inserted seat post with the 380mm long reverb
Posted : 11/08/2012 9:48 am
 br
Why not just get the 420mm, just in case (plus use on other bikes). Or am I missing something?
Posted : 11/08/2012 9:53 am
extra weight?
Posted : 11/08/2012 10:22 am
also didnt want to risk the post not fitting all the way down as the current seatpost gets tighter and tighter towards the bottom when fully dropped
Posted : 11/08/2012 10:26 am
Got a 380/125 30.9 on my large 2011 spot.
It will go fully into the frame if required.
I had to "clean out" the internals of the seattube just to make sure of no catching/scoring as discussed in one of the earlier threads, all is now ok.
Posted : 11/08/2012 12:39 pm
stupid question but is the bottom fat bit exactly half of the total length if you know what I mean or a bit longer?
Posted : 12/08/2012 11:47 am
