Hello,
have this head set:
[url= https://www.uberbikecomponents.com/view-product/Uberbike-15-Headtube-Tapered-Fork-Headset-Stainless-Steel-Bearings-Green ]Headset[/url]
Can in be converted to 1. 1/8th via a different crown race of adapter?
Many thanks
Liam
Yes, Hope do a crown race adapter that will change your forks from 1 1/8th to 1 1/2
Double post
[quote=ssboggy]Hope do a crown race adapter that will change your forks from 1 1/8th to 1 1/2
As long as the angle of the contact patch of Hope and Uber bearings /crown races are the same - they probably are, but it's not a given (why you should generally use the crown race that comes with the headset).
Hope's crown race adaptor is just that - an adaptor - so you'd use your existing 1.5 race and bearings and the Hope jobbie just resizes it to fit your 1 1/8" steerer. I've used one in the past with no problems to fit older 1 1/8" Lyriks with a tapered headset.
[quote=mamadirt]Hope's crown race adaptor is just that - an adaptor - so you'd use your existing 1.5 race and bearings and the Hope jobbie just resizes it to fit your 1 1/8" steerer. I've used one in the past with no problems to fit older 1 1/8" Lyriks with a tapered headset.
My bad, I always presumed they replaced the original crown race.
