Can somebody please...
[Closed] Can somebody please explain MIPS to me
And any reason why I shouldn't have purchased a TLD A1?
Trying to get my head (pun intended) round how MIPS works and what it truly offers in all scenarios of offs..?
Posted : 22/02/2015 11:53 pm
Millions of Instructions per Second. Once considered the best way of comparing the performance of computers.....
Posted : 22/02/2015 11:54 pm
๐Ÿ˜†
Posted : 22/02/2015 11:56 pm
and using those Million Instruction per Second in the googleatron
http://www.mipshelmet.com/#what-is-mips
Posted : 22/02/2015 11:57 pm
I believe it lets inner and outer shell rotate separately. Helps minimise potential for rotational injury.
Posted : 22/02/2015 11:58 pm
Jamj - that's as far as my info intake I could take after becoming overloaded with jargon so far.
Posted : 22/02/2015 11:59 pm
Imagine the side of your helmet strikes the ground as you are sliding along after a fall. When your helmet hits the ground it will spin, twisting your neck and rotating your head from a standstill very quickly. Your skull, being fixed in the helmet, will rotate at the same time as the helmet, but your brains are sort of loosely attached inside your skull and will take a while to get up to speed. That difference in acceleration of your different head parts can be fatal.
If you can slow the rate of acceleration of your skull inside the helmet, your brain doesn't get left behind and so you can prevent certain injuries.
Posted : 23/02/2015 12:03 am
