Can i use a hi clam...
[Closed] Can i use a hi clamp front mech on a trance x?
Like that /\ instead of this:
Posted : 01/06/2010 11:00 pm
isn't the tubing kinked a bit too low down for that, so you need the low-normal one?
Posted : 01/06/2010 11:03 pm
thats why i am asking cheers
Posted : 01/06/2010 11:05 pm
what do ya think?
Posted : 01/06/2010 11:08 pm
Geewavetree: looks like you have removed the ugly bash guard from the double SLX crankset? Does this work OK? Shorter bolts needed?
Posted : 01/06/2010 11:16 pm
my trance (100mm travel 08) came with a conventional swing like the one you want to use
Posted : 01/06/2010 11:35 pm
I'm thinking of going two up front on my trance, maybe with a 34 tooth.
Posted : 02/06/2010 7:33 am
Buzz - that is a triple version - swapped the rings for 24/36. The ratios are ace, the changes slightly clunky, and teh chain drops off the big ring on bumpy stuff, other than that its good ๐Ÿ˜‰
Posted : 02/06/2010 8:37 am
I recently got the double and bash from CRC which is 22 36 but with a triple mech. The shift is a clunk but works OK and the ratios are good. The bash is bigger than I expected and I was wondering about removing it but for the dire warnings on the sheet.
Posted : 02/06/2010 1:10 pm
to clarify - DOES NOT FIT ๐Ÿ™
Posted : 03/06/2010 8:07 pm
