Can I run an inner ...
[Closed] Can I run an inner tube on a tubeless rim?
While I await delivery of a tubless tyre I'm wondering if I can run a standard tyre with inner tube on the rim?
It's a carbon rim without the little flanges along the edge that a normal tyre would hook under.
Thanks.
Posted : 23/03/2016 6:37 pm
Yes but I'd try it tubeless first - if it doesn't work chuck a tube in.
Posted : 23/03/2016 6:40 pm
If there's no bead on the rim then no tyre will mount, tubeless or not.
What rims are they?
have a look at this
http://www.bikeradar.com/mtb/gear/article/trail-tech-off-the-hook-40749/
Posted : 23/03/2016 6:42 pm
They are Chinese hookless rims.
[url= http://www.ebay.co.uk/itm/261974414505?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT ]Here[/url]
Posted : 23/03/2016 6:44 pm
If there are spoke holes on the rim bed, [url= &imgrefurl=http%3A%2F%2Fwww.light-bicycle.com%2Fenduro-downhill-mtb-26er-carbon-rims-38mm-wide-hookless-tubeless-compatible-strongest.html&docid=sbf9MwiKzuSL6M&tbnid=ggrgh3OUInwyZM%3A&w=978&h=478&ei=utnyVsmDA-ixygPIvYxA]Like This[/url] you'll need some rim tape mine didnt come with any.
But I run my hookless carbon rims with regular tubes and tubeless ready tyres fine.
Posted : 23/03/2016 7:01 pm
Thanks Matty they are just like that! I will go tubeless but all I'm waiting for now to be able to finish my build and ride my new bike this weekend is a tubeless tyre! If it doesn't arrive it will be down to my lbs who only do standard tyres. Thanks.
Posted : 23/03/2016 7:07 pm
