Can I fit a 11 spee...
[Closed] Can I fit a 11 speed road cassette to a MTB hub
 SOAP
looking at fitting some 650B Superstar wheels (Switch Ultra hubs) to my cotic Escapede.
Posted : 22/12/2017 9:59 am
 SOAP
I think the answer is NO! 🙁
Posted : 22/12/2017 10:09 am
No the 11 speed road cassettes are wider than 10 and 9 which do fit on a mountain bike hub.
Posted : 22/12/2017 10:10 am
 qtip
You can on the latest Hope hubs. There may be others.
Posted : 22/12/2017 10:11 am
You can fit the new 11/34 cassette as it’s the same width as a mtb cassette, you have to add a spacer on a road wheel
Posted : 22/12/2017 10:34 am
 SOAP
Crazybabboon can you post a link to that cassette please
Posted : 22/12/2017 10:56 am
I've not seen these, surely that would throw your indexing out on a road bike? Or is this to be ran on a road bike using a mtb mech? In which case, surely this is just an MTB cassette?
Posted : 22/12/2017 11:06 am
 SOAP
Just to add I’m running sram rival hydro brake/shifters and mech.
Posted : 22/12/2017 11:10 am
The Shimano CS-HG800 11/34 will fit a standard 8/9/10spd freehub body.
Posted : 22/12/2017 11:30 am
 SOAP
Can anyone answer my indexing question, what mech would work with this and an 11speed shimano 105 shifter?
Posted : 22/12/2017 11:38 am
An Ultegra R8000 GS will work with it.
Posted : 22/12/2017 11:39 am
Simondbarnes is correct (as usual)
Posted : 22/12/2017 11:48 am
I'm presuming this means that Shimano are bringing 12 speed sometime soon if the 11 speeds have been made narrower like an mtb one?
Posted : 22/12/2017 11:54 am
The 11 speeds haven't been made narrower. Where did you get that from?
Posted : 22/12/2017 11:56 am
The fact that the above one can fit a 10 speed cassette body?
Or are those r8000 not the same width as a mtb cassette which had been suggested earlier in the thread?
Posted : 22/12/2017 11:59 am
The largest cog is offset over the ends of the spokes.
Posted : 22/12/2017 12:05 pm
It's not narrower though. They've spaced the 34t sprocket over the back of the hub flange like they have with 11spd mtb cassettes.
Posted : 22/12/2017 12:07 pm
As above, it’s an 11 speed road cassette with road indexing. It’s just the offset on the carrier that means it sits closer to the spokes.
Posted : 22/12/2017 12:28 pm
So basically its a mountain bike cassette? Presuming you could fit a mountain bike 11-36 with a spacer if you were so inclined?
Posted : 22/12/2017 12:32 pm
Alternative is you get a road icon ultra freehub
https://www.superstarcomponents.com/en/icon-ultra-11speed-freehub.htm
And stick it on your switch freehub. Superstar say it won’t work but I’ve done it with mine.
Posted : 22/12/2017 12:37 pm
No, the indexing would be off
Posted : 22/12/2017 12:38 pm
I think I get what you mean, does that mean the teeth on the largest sprocket are actually in line with the spacer you run?
Posted : 22/12/2017 12:42 pm
Kind of yes. Basically ignore the idea of a spacer and think what the cassette looks like from the inside, a larger gear such as a 34T has more inner ‘space’ so won’t hit the spokes at the same point a 32T or smaller would. Hence it can be offset more which means the carrier itself doesn’t have to be so long.
It’s a little bizarre why shimano make it suitable for MTB hubs considering their 11 spd road and mtb gearing is incompatible, but It does have advantages for swapping mtb wheelset a across bikes ( I may be answering my own question here!)
Posted : 22/12/2017 1:02 pm
If you were running one on and 11spd road hub? Yeah, I guess it'll be about there.
Yes, although the R8000 GS rear mech is only rated to 34t.
Posted : 22/12/2017 1:12 pm
The pull ration for the ultegra mech would be off though surely?
Posted : 22/12/2017 1:56 pm
It isn’t but I believe it’ll take more. My Sequoia has a 105 mech and an 11-36 cassette.
Posted : 22/12/2017 2:02 pm
No, the ultegra mech will work perfectly with his 105 shifters. As for the cassettes, the spacing is the same and Shimano road & mtb 11spd use the same chain.
Posted : 22/12/2017 2:13 pm
I get the bit about the mech and the shifters working together. It was where you suggested he could fit a shimano 11 spd mtb cassette and it would work with that set up.
Posted : 22/12/2017 2:44 pm
If Shimano actually made an 11/36 11spd mtb cassette he probably could. I doubt an 11/40 would work without using a goat link or similar.
Posted : 22/12/2017 3:28 pm
I’ve got the 11/34 cassette on some Mavic crosmax slr mtb wheels which I use on my cross bike, the indexing is near enough to a normal 11/28 cassette on my other wheels, certainly no worse than swapping with any other wheel
I’m using a medium cage ultegra 6800 rear mech, but I wouldn’t be surprised if it works on a short cage, as I use to run a 11/32 with ease on a short cage, of course it depends on the length of the rear derailleur hanger as they all differ!
Posted : 22/12/2017 4:52 pm
Every day is a school day on Single Track
Posted : 22/12/2017 4:59 pm
 SOAP
I’ve got a short cage Rival mech which might not work.
Has anyone got medium cage Sram Mech for sale?
Posted : 22/12/2017 6:27 pm
You can also machine 1mm off a road cassette to fit an MTB hub - I run 11-30s on my cross bike wheels (which run Hope Pro 2 hubs).
Posted : 22/12/2017 8:02 pm
 SOAP
Ordered a 11/34 R8000 cassette and some tyres yesterday from wiggle/CRC which havert arrived yet, but also ordered a 11/30 cassette a bit later which has arrived
No way to make the 11/30 fit apart from losing a mid ratio cog and putting a spacer behind the cassette.
Making it 10 speed but with 11 speed spacing.
What makes the 11/34 different from the 11/30 allowing it to fit?
Posted : 23/12/2017 11:31 am
The 34t sprocket is dished over the inside of the hub flange like on the Shimano 11spd mtb cassettes. A 30t sprocket isn't large enough to enable this to be done so will only work on 11spd freehub bodies.
Posted : 23/12/2017 11:34 am
 SOAP
Ok thanks.
So would it work OK as a 10 speed with the limit screws adjusted.
I would have to purchase a new mech to run the 11/34.
Posted : 23/12/2017 11:41 am
The 11 30 cassette will fit if you machine off 1mm from the carrier. A BB facing tool works nicely for this.
Posted : 23/12/2017 12:16 pm
Or buy a Roadlink, depending on current derailleur
Posted : 23/12/2017 1:39 pm
 SOAP
The 34 works perfectly apart from the rear mech needs a longer cage as it won’t shift onto the 34
700c to 650b
Thanks guys
[url= https://s19.postimg.org/uy0n3ehvn/D7525_FD3-6307-48_DB-8_D11-419744_E290_D1.jp g" target="_blank">https://s19.postimg.org/uy0n3ehvn/D7525_FD3-6307-48_DB-8_D11-419744_E290_D1.jp g"/> [/img][/url]
[url= https://s19.postimg.org/mfr6z2j2r/0_B24_ED5_F-_C057-4934-8929-_A0331_BB34_FCB.jp g" target="_blank">https://s19.postimg.org/mfr6z2j2r/0_B24_ED5_F-_C057-4934-8929-_A0331_BB34_FCB.jp g"/> [/img][/url]
Posted : 24/12/2017 2:51 pm
