Can anyone recommen...
[Closed] Can anyone recommend a drift/punch for free hub bearings?
Normally use a screwdriver for bb and hub shell bearings but I’m struggling to get purchase on the bearings in a hope pro 2 evo hub body to knock them out
James
Posted : 04/02/2021 8:41 pm
Don’t you just use the axle for the hub shell bearings?
Posted : 04/02/2021 11:12 pm
Have you levered the spacer between the 2 bearings over to one side before trying to drift the bearings out?
Posted : 04/02/2021 11:15 pm
Worth getting an assortment punch set, they're not expensive and having a few different tools gives you more methods of attack. Having some random bits of metal in the right sort of shapes is handy- I had one bearing that was a total bollocks but that a bit of old threaded bar took out no bother.
But I bsically have 2 that I use the most, one is a fairly thin machinist's punch that got completely mangled at some point and is both bent and a bit mushroomed at the end, which is amazing for getting into little gaps. And teh other is the rear axle from a '00 suzuki sv650, which is perfect for really smacking stuff.
Posted : 04/02/2021 11:17 pm
.....is making my teeth itch!
Buy a set of parallel punches and a soft brass or aluminium drift you heaven!
Have served me well;
https://www.mytoolshed.co.uk/starrett-s248pc-long-pin-punch-set-5pc
Posted : 04/02/2021 11:53 pm
Just realised you can push the inner sleeve to one side. Thanks for the responses I’ll buy that punch set now
Posted : 05/02/2021 10:51 am
Personally I like parallel pin punches which taper to the handle (prevents skin getting pinched and damage to the work piece when the punch slips.
Rather than these
Both types work, I just tend to reach for my tapered ones first 90% of the time.
Posted : 05/02/2021 11:01 am
On my formula freehub, you have to move the spacer/sleeve to one side and drift out the outer bearing. The inner bearing is secured with a circlip - fortunately I realised that first time when they wouldn't press out !
Posted : 05/02/2021 11:11 am
