Can a 2x10 front mech be used on a triple crankset that is set up as a double and a bash?
Posted : 18/04/2013 1:16 pm
Yes, the spacing of the rings is the same. The chainline is slightly different (1.3mm) than a true double crank, but there should be enough adjustability in the front mech to accommodate this.
Posted : 18/04/2013 1:22 pm
Thankyou PerthMTB
Posted : 18/04/2013 1:33 pm
Oh, one other thing to consider - if your bash is significantly larger diameter than your 'big' ring it may foul the FD cage. If so, you'll need to set the FD a little higher than ideal (or get a smaller bash!)
Posted : 18/04/2013 1:39 pm
