calling bearings ex...
[Closed] calling bearings experts
 jeb
So i have a 15 mm 350 DT swiss hub, i want to put some grease in the bearings, so i removed the red dust seal, behind that is a kind of metal cover, so i cant see the ball bearings, should i still smear some on it ?
Posted : 02/10/2013 5:59 pm
Are you sure it's a cover and not the cage that holds the balls in place ? Often the cage is flat on one side.
If you've got the bearings out, remove the other rubber seal and the cage will look more bumpy.
Posted : 02/10/2013 6:15 pm
Around the metal cover is a thin ring keeping it in place with a break about 2-3mm, use a pin where the clip has a gap to pop it off.
Posted : 02/10/2013 6:44 pm
 jeb
The cover is kind off bulky, i tried gentley to pry it off, but could not, so i think i just try to give it a dab of grease ๐Ÿ™‚
Posted : 02/10/2013 7:09 pm
