I quite fancy a slate for hooning around the local trails etc, and some bikepacking/touring.
What's the widest tyre that would fit in the rear? Bit optimistic hoping a 2.1 nano would fit but hoping my Schwalbe 2in marathon would go.
I think max width is about 45mm. No where near what you would like, and of course thats 650b only.
I think Cannondale really missed a trick with this. I like the idea of the Oliver front end but why did they limit themselves to 650b tyres when most rough stuff type frames seem to be going 700c X 42 or 650b X 52 like Mason, UP and Reilly
I have a Slate, max width on the rear is 42mm. Agree that they missed a trick by not giving more rear spacing, but with a pair of G One's fitted you don't miss a wider tyre.
Incase you haven't seen Wheelbase have the Slate range on sale.
http://www.wheelbase.co.uk/catalogsearch/result/index/?cat=4&q=Slate
Thanks, the bike I have takes 47 horizons ok so no point. As said, missed opportunity given that they were quite early to the 650b trail bike party( to some degree at least).
The 2017 Slate can be had with 20-35% off at Evans, Cycle Store & Wheelbase amongst others.
Are they clearing the stock before next year's model arrives?
Or is there an issue with them?
@elshalimo - more like the concept is a bit niche and it's a slow seller over here. Great bike tho, imo.
I think an optimised design is good - it shows in the ride / handling. Some/most of the 'dual size' bikes are just 700c bikes that have the clearance for 650x50 - doesn't mean they handle that well with the 650s though, particularly if loaded up. Just ime/imo though. I'd agree that 650x42 limits options now there are bigger tyres available but for road and a bit of dirt use, 42c is pretty good. Certainly fast. If I was on poor tarmac and good gravel roads 95% of the time 42C might be the ideal.
Hi
I bought one of the CX1 slates at wheelbase. On my second day I had it I competed a century ride solo which took me 6hrs 15mins. This was a mix of disused railway and b/country roads. This was only a few
Minutes longer than a previous century on a 700c cx bike. Amazing bike amazingly comfortable. Only change planned is a set of schwalbe g ones and tubeless (on order).
Don't be put off - I was a little unsure but am glad I did get it.
Does anyone happen to know if the rear mech on the 105 Slate is short or mid-cage?
Interesting that Cannondale have launched the SuperX SE (Special Edition) today as their "gravel" bike.
Its just a cx frame with some adjustment to take slightly wider tyres.
Seems they still haven't got it!
I'm genuinely glad you like the Slate. For me, it just doesn't have the flexibility of tyre choice that I need for my style of rough stuff riding.
FWIW I've decided on the Reilly Gradient.
Not sure you'd still say that if you tried to follow their frame engineer on a gravel road tour ; )Seems they still haven't got it!
'Getting it' vs 'having their take on it' perhaps.
I have the force 1 slate. In the black, I ride it in the hills around huddersfield,/ Peak District area, it's great fun in fast woodland, i put a shorter stem on mine. 80mm, replacing the 100mm one and went tubeless with the G one tyres. I only use it for a couple hour blasts really, that's all I wanted it for. Specialized do a drop bar called the hover which has a slight rise in it which I may get to aid in the neck comfort.
overall. A great purchase. Yet to see another one out n about
Dammit. Just noticed that Evans are offering £250 off an already-reduced Ultegra Slate (or other similarly priced bike) if you trade in any old shitter. Ends tomorrow. Obviously I [i]want[/i] one, but do I [i]need[/i] it? 🙂
That is a very very good deal with the trade in offer on top... very
I know!!
an offer I can't refuse?! 😆
For some reason I'm trying to justify it with man maths
But it would be the biggest waste in the world to commute on the road using a Slate
well commuting is one thing I'd want it for (although not just that), lack of rack/mudguard mounts is off-putting though!
EDIT: or maybe it does have eyelets, at the rear? conflicting reports online, & can't 100% tell from a pic...
There are proprietary mudguard mounts on the rear, never seen anywhere stock the guards though.
Possibly not helping but I bought their last Norco Optic C7.3 which was on sale. Click and collect via Topcashback will pay for the pedals and they gave me 250 quid for a 28yr old rust bucket with a dented top tube. Worryingly I also had really good, knowledgeable service from them too 😯 (MK Xscape branch).
I'm thinking of getting a slate. I was wondering about sizing, I'm 6'2" with a 34 inside leg. Large or Xlarge?
I (Very)briefly had a slate in large, I am 6'1 34" IL and it was the right size.
May I ask why you got rid of it? Just curious.
You can fit a rack. You just need to use one with the flat steel arms rather than the solid bar type for attaching at the top of the back of the seat stays.
Absolutely loving my Slate CX1. Bought on a whim to replace my full on road bike after seeing the psa on here. I'm 6'1 and about 32" inside leg and went for a large. Seems pretty much spot on size wise.
With regards tubeless mine came supplied with Mavic rims rather than the Cannondale branded ones which I believe were recalled. I had some 3 quid Specialized/Roval valves kicking about so chucked those in and a scoop of Stans in each and so far no problems.
