I have hope m4's and some formula The One brakes, front and rears of both...
The hopes have a lazy piston and are going to be looked at to try and sort, but can I mix hope mc's with the formula caliper?
I never managed a good bleed that would not go soft with the formula brakes so I'm reluctant to fit these again. They were great when they worked for a bit, but a pain to keep bled and working, they always seemed to ingest air....
Posted : 27/07/2017 6:01 am
Assuming th e formulas use dot fluid then no damage will be done. It might not work well if they use different piston sizes tho.
Posted : 27/07/2017 6:08 am
Just try it for yourself and report back! I've paired a SRAM Rival 1 lever with a Hope Mono-mini caliper and it's been absolutely fine.
Posted : 27/07/2017 8:10 am
