C456 vertical dropo...
[Closed] C456 vertical dropout bolt problem
Afternoon everyone,
Been getting an annoying frame sounding click from the back end of my C456 which is evident in hard pedaling or if you hold the rear brake on hard and rock its easily heard. Thought it may be the wheel hub so tested it on another bike and wheel is ok.
So checking all bolts etc, found one of the drop out bolts slightly loose but wont unscrew out of its female counterpart (the whole female component which the screw tightens into keeps spinning within the frame). Tried wedging a flat headed screw driver at the back of the bolt as it has a couple of indents, but still wont move.
Anyone else had the same problem...Im hoping the only option is not drilling it out.
Rgds
J
Posted : 25/08/2013 3:20 pm
 nuke
Its the same as chainset bolts. Think I use a 1p in the indents to do them up. Never got around to buying...
http://www.chainreactioncycles.com/mobile/park-tool-chainring-nut-wrench-cnw2c/rp-prod14305
Posted : 25/08/2013 3:39 pm
Cheers, glad there is a tool for it. Funnily enough was on a ride last night with a friend who said the same thing and could have a tool I could borrow. Sounds easier than drilling the thing out.
Many thanks
J
Posted : 26/08/2013 9:00 am
