Cracked my Tracer at the usual spot by the chain yoke, drive side. To be fair, I was hammering it over rock gardens like they weren't there.
Importer offered a new swingarm for £700 plus "at least" 6 weeks for delivery. Once the bike shop had stopped laughing I respectfully declined.
Picked up a complete 6.6, stripped everything and rebuilt it with my kit.
It's red NOT pink!
Nice.
I like pink bikes 🙂
very nice,spec looks great
but you shouldve cleared your draining board first
Looks great! Any vague idea on weight? I have a 6.6 in excellent nick I've used as an Alps bike sat around doing nowt. Looking at that, it might be fun to get it down to trail bike weight if not too pricy.
Carrier bags in the toaster is an interesting choice.
Bike looks good 🙂
"I'm gonna build my bike in the kitchen" - "only if you do the dishes first"
It's not mad heavy, touch more than when it was built up as a tracer which was really a full day XC bike. The fork has a lot of the weight, but it's worth carrying round for the performance.
If it's anything like the last bike, it'll gradually spin uphill and beast the otherside.
Saxabar, drop us an email, I've got a fair bit of the original build kit left over to clear out if you're interested? DT Wheels, brakes, X4, Joplin etc.
Nice looking bike that Warwick. How dies it ride with those forks on the front?
Cheers Sam, well, in the one side of Kendal to the other test it seems allright, should get it off road this weekend. Was worried it'd be too tall but the ATA means I can wind it in and out to whatever I need.
Hi Wozza,
My Tracer VP has also developed the dreaded chainstay yoke crack 🙁 It is laughable that Intense will not (at worse) supply a new swing arm at cost, but as it's clearly a design fault (hence the beefed up swing arms,) it should be a free replacement regardless of how long the original owner has had the frame....
Anyhow I digress - do you know if the 6.6 swing arm would fit the original VP?? Could you please measure the necessary dimensions between your 2 frames to see if it is at all possible?
Cheers,
M.
Nice bike 🙂 but it looks pink to me..
I've got an early Spyder swingarm hung up in the garage if anyone's in need of one, was quoted £800 for a front triangle by the importers, who can KM (hairy) A...
Looks nice Wozza.Is it 'works red'?
Love my 6.6 and have built mine to my perfect spec. Had it resprayed in Candy Red as it's the closest I could find to 'works'. One thing I did that made a nice difference to the ride was make some offset bushes. Got about 1.5 degree slacker head angle. I did feel a little on top of the bike but with the offset's it made a big difference. Goes down brilliantly and climbs relatively well. Got rid of the coil now too for a Pushed CTD TA. Fantastic shock and really works better than the coil ever did.
Can we do a 'show me your red Intense'? Great, here's mine:
[URL= http://i729.photobucket.com/albums/ww299/deesta-pics/Intense/IMAG1718_zps07b825ae.jp g" target="_blank">
http://i729.photobucket.com/albums/ww299/deesta-pics/Intense/IMAG1718_zps07b825ae.jp g"/> [/IMG][/URL]
A few changes to mine since this was taken. Brakes are now Formula RO's, Zee rear mech and the horrid white cables are gone too.
Mooseman, replied to your email. Off memory the lower link is the same but I think the upper part is longer.
Khani, I'll drop you an email about that spyder swingarm to see if I can make a Franken-ense out of my old tracer front end.
Stevied, I don't think it needs offset bushes, I have a 180mm ATA fork so I can wind it slacker or steeper all day. I like that red of yours, Mines a flat red but a mate has the team red tracer that like a candy colour.
As soon as the bearings need doing though, it's getting stripped to look like this:
[img] http://www.socaltrailriders.org/forum/attachment.php?attachmentid=17519&stc=1&d=1206940347 [/img]
Wozza YGM
Mine was raw when I bought it (2nd hand) but it hadn't been done very well. Looked really nice when I'd stripped ut properly abd bead blasted it and did think of keepping it like it but loved the candy red.
I've got an old bottom pivot/bolts etc if you need one for the Franken-tense
