Building with Stans...
[Closed] Building with Stans Flow?
I've fancied building a wheel for a while and now have a spare rear Pro2 hub, so thinking of making a second set of xc wheels for my bike - main/current set is bulb/D521, so something light and tubeless would be a useful addition.
What is the Flow rim like to build with, as a beginner? Is it a bit ott for xc, given that I have D521s for harder riding? Maybe the Arch would be strong enough and a bit lighter?
Cheers!
Posted : 03/03/2012 10:56 am
1st wheel I ever built from scratch was a flow - went absolutely fine
only probs were psychological ( ๐Ÿ˜• ) as they say you should use a bit lower than normal tensions and I'd never built to "normal"
wheel is fine though, 18 months on (mind, that's about 45 minutes riding for me)
Posted : 03/03/2012 10:59 am
Wheel building is easy. If you are near Glemsford Suffolk I will happily show you in my shop (I won't even charge given you are determined to give it a go).
Posted : 03/03/2012 11:40 am
The lack of ferrules makes them trickier but it's not a huge issue for most - just lube up your nipples first.
Posted : 03/03/2012 11:43 am
In a similar position with spare hub and would like to build a wheel but cant see the point. If I sell the hub and fund a fully built wheel it comes in cheaper. Am I missing something?
Posted : 03/03/2012 11:52 am
Some people enjoy learning new skills and working with their hands, I guess you don't.
Posted : 03/03/2012 12:06 pm
No - would like to do it, just think that it should work out cheaper. I'd probably get spoke length wrong and it would end up costing more, that's all. Need a cheaper rim I suppose. Flows are expensive new, as are spokes it seems.
Posted : 03/03/2012 12:18 pm
try sdeals.com for cheap spokes, and spoke length is not as critical as you'd think, plenty advice/calulators around too.
Posted : 03/03/2012 12:22 pm
Cheers guys, will give it a go. bm0p700f - thanks very much for the offer, I am in Yorkshire so can't take it up unfortunately!
Posted : 03/03/2012 1:32 pm
