Buffalo Teclite
[Closed] Buffalo Teclite
[#7532124]
Morning all, I'm looking at getting a Buffalo Teclite for biking and running duties.. does anyone on here have experience of them?
Posted : 22/12/2015 9:33 am
IME, Buffalo are still not cut as well as Rab or Montane who offer similar things.
Still a very warm option for high energy sports - my old Montane used to come into its own around freezing with a baselayer below when pedaling.
Posted : 22/12/2015 9:37 am
Which rab or montane would you recommend Matt? I want something for wild rides, that will keep me warm and dryish (or at least warm when wet) and be packable
I tried the Rab VR and thought it might not do the job as well as a Buffalo would?
Posted : 22/12/2015 9:54 am
I wear a Rab VR Alpine Lite for biking, really like it
Don't wear my buffalo shirt, it's slightly too big for me but it's massively warm
I'd guess a Rab VR is less cool than a Buffalo shirt (assuming a Teclite is the normal pile pertex job)
Posted : 22/12/2015 10:26 am
Rab VR Lite at the moment, unless you can find an old Montane Krypton
Posted : 22/12/2015 10:37 am
christ, if I ran in one, I think I'd probably pass out!!
Posted : 22/12/2015 11:03 am
Teclite is the lighter Buffalo; thinner rip stop pertex outer with a micropile inner. I've used mine for mtb rides in the past. Not going to pack small enough to put in a jersey pocket like the windshirt but such good venting you could wear it with a base layer or next to your skin as recommended. Mine is the foldaway hood version, not cycle specific. The hood is useful when you stop but not big enough to go over a helmet if that's your thing.
Posted : 22/12/2015 11:26 am
Thanks all, she'd brewed that was the one I was looking at, do you rate it?
Posted : 22/12/2015 1:04 pm
I have a buffalo active lite shirt (ripstop with thin pile, no hood) and its my favorite riding top at this time of year, really really good. I did the Yorkshire dales 200 in it earlier in the year and for 22 hours all I did to regulate temperature was zip and unzip it, if I got really warm id tie it around my waist. I was looking at replacing it with the teclite cycle shirt but the sleeves are crazy long (3 inches longer per size than my active lite) that they just look ridiculous bunching up around the wrists. I'm looking at the snugpak equivalent (TS1 smock) as a cheaper replacement as I can get them directly from the factory.
Posted : 22/12/2015 1:48 pm
 Solo
[i]Buffalo Teclite[/i]
I thought this was another Star Wars thread!
Posted : 22/12/2015 2:04 pm
Rab Generator is all you need, packs down super small, breathes really well and is still warm when wetted out......I find all my Buffalo gear to hot to do any exercise other than walking or sitting watching the rugby in.
Posted : 22/12/2015 4:22 pm
Or you can look at the Marmot dryclime it does the same thing, in use one for winter running
Posted : 22/12/2015 4:32 pm
Bedds, yes I do. It's a tough piece of kit.
Posted : 22/12/2015 10:32 pm
Thanks chap.. that's good enough for me
Posted : 22/12/2015 11:42 pm
I have a rab vapor rise lt (actually I have all 3 weights of VR 😳 ) and just it plus a base layer is enough for biking in -10C in Canada. Add a generator smock and I'm good to -20C if there isn't much stopping. So a big thumbs up on the warm and fit side; can't comment on the wet front so much.
Posted : 23/12/2015 12:31 am
I use a Rab VR for almost all my winter rising. One of its good points is you can pull it up to your elbows to help vent heat - but check that if you try one on because I can only just get it past my forearms.
[url= https://farm4.staticflickr.com/3715/9136292373_cb84c58f0b_c.jp g" target="_blank">https://farm4.staticflickr.com/3715/9136292373_cb84c58f0b_c.jp g"/> [/img][/url]
I carry a Montane Pertex in a pocket for when it gets really wet and just slap that on over the Rab.
For long rides in deep snow or if there's going to be sleet, I'll take my Buffalo 6 smock.
Posted : 23/12/2015 8:53 am
I also have an active light shirt, albeit a slightly older one, I think they changed the rip stop.
Its a great top, use it most of the year. Its really tough, so loads of grit doesn't wear or split the fibers. Its Mega vented too.
Ill buy another.
Posted : 23/12/2015 10:19 am
Suggsey, you ride in a Generator and find it breathable? Surely not sweaty rides? That top is designed to be warm and windproof, not breathable. I'm surprised it's working for you in that way, it's meant as an insulated top for gentle output activities or more likely for when you stop
Posted : 23/12/2015 11:14 am
