Budget forks
[Closed] Budget forks
Which is better a Suntour Epicon or a Rockshox xc32 solo air. Or am I better with a coil fork?
Posted : 16/09/2013 12:23 pm
Budget?
I've been tempted by the marzocchi corsa RC SL's on CRC for £270, seems to be just RS and Fox playing sillybuggers with the pricing, Marzocchi and Manitou are looking like bargains at the moment.
Posted : 16/09/2013 12:26 pm
£200 at the moment
Posted : 16/09/2013 12:33 pm
Your probably better off buying some second hand Revs and getting them serviced.
Posted : 16/09/2013 12:45 pm
save a bit more and get a decent fork, rather than wasting the cash on something poor. Or go 2nd hand..
Posted : 16/09/2013 12:49 pm
May just save up and buy some Reba RL.
Posted : 16/09/2013 1:11 pm
Trying to find so which are 9mm qr but none in stock. Do I need Air forks or will coils suffice? I have Tora Coilson my Vulcan and they are plush compared to the xcm suntours.
Posted : 16/09/2013 3:04 pm
Coils are fine, they tend to be plusher but you need a coil specific to your weight (fine if your 'normal' but thinner or fatter ppl usually need a different coil from std) and tend to be heavier overall fork. Air forks tend to be lighter and can be matched to a rider weight by mean of more less pressure in the fork.
Just watch that there enough steerer for the new frame, before embarking on swapping them. Not a difficult job otherwise, assuming you don't need a different brake adapter (not difficult just more expense)
Posted : 16/09/2013 3:45 pm
I weight about 68kg so don't know if that's too light for coils.
Posted : 16/09/2013 3:46 pm
Depending on the model I'd guess it's just means you need a Normal spring [as opposed to a fork that's got a Firm, or Soft spring fitted].
Most companies sold the same fork with different springs available as aftermarket options for [url= http://en.wikipedia.org/wiki/Fattypuffs_and_Thinifers ]Fattypuffs and Thinnifers[/url]
Posted : 16/09/2013 3:49 pm
Seen some Manitou R7 pro 100mm £199 at on one. These any cop? The claimed weight is on par with Reba rl 1500g they seem ideal.
Posted : 16/09/2013 7:02 pm
Dunno man. I always like Manitou for the damping, but I think their chassis development was behind the curve 'till very recently.
Check Bikeradar.com, MTBR.com etc etc
Maybe start a thread called "If I buy Manitou R7 pros, will I die?"
Posted : 17/09/2013 12:30 pm
I may just buy a epicon x2 can be had for £150. Light too at 1650g
Posted : 17/09/2013 3:38 pm
