Brand X Dropper Que...
Brand X Dropper Query ... Sticky Pin ... Ooh er
Afternoon All,
I have a Brand X dropper that suffering with a sticky release pin - Specifically the pin that the cable rocker pushes on to actuate a drop and release.
On a couple of occasions the (bar mount) lever just won't exert enough force to move the post initiation a fafftastic removal from the frame and the pin pressed in with a screwdriver to get it working again.
Do I resign myself to it just being a bit of a dud or is there something that can be done to help the issue?
Posted : 05/11/2024 2:44 pm
I'd have put a drop of oil on it and exercised a few times while it was out. Probably with the pin depressed as far as possible because IIRC they're a bit tapered at the tip so you'd get a bit drawn into the bore that way.
Posted : 05/11/2024 3:09 pm
A generous blob of the thickest grease you have got (I use stern tube grease) on and around the pin might help lower the frequency of it seizing up. That's what I do with the two Brand X posts I've got.
Even then if you ride in wet conditions a lot, water will eventually wash away the grease, so it won't be a permanent solution!
Posted : 05/11/2024 6:55 pm
Why grease Mr Copperpot? I'd want something that will get drawn in by the capillary action in that application. Interested in your reasoning.
Posted : 05/11/2024 8:02 pm
Did you read this part
It's very old way of slowing down/preventing water affecting parts where no other protection is available. Depending on the application replenishing the grease may be a regular or almost a non-event.
Almost a non event with the 2 Brand X posts I own. It has pretty much stopped the corrosion down there.
Posted : 05/11/2024 8:15 pm
I have to drop a small amount of oil on the lever cable every few months, on my Brand X
Posted : 05/11/2024 10:51 pm
Another one who smears the mechanism with grease and lubes the cable here.
Posted : 05/11/2024 11:08 pm
