Brand new Formula f...
[Closed] Brand new Formula floating rotor warped out the box
Normal? should I send it back or just fix it?
When one half of the disc is true, the other half appears to be just out enough to contact the pad with a light rub.
Posted : 06/06/2012 12:48 am
For that amount of rub, I would just try bending it to see if it would true. Probably less hassle than sending one back and getting a replacement. I've seen some so bent that the wheel wouldn't turn at all.
Posted : 06/06/2012 12:53 am
Meh....I don't think Mountain biking is good for me.....set's off OCD I reckon.....nothing ever just works out the box does it. Will give fixing them a go!
Posted : 06/06/2012 12:56 am
That's totally normal.
When you use it the first time the heat thats generated will true it up.
Posted : 06/06/2012 7:49 am
Did you tighten the rotor bolts one after the other or in opposing pairs? Rotors never seem to come out of the box perfectly straight. Always need a little tweaking, even when you do the rotor bolts properly.
Posted : 06/06/2012 7:55 am
WTF????
How hard is it to make them straight?(everyone else seems to manage) If it were me it would be back to the shop for a new rotor.
Posted : 06/06/2012 7:57 am
