Brake squealing, wo...
[Closed] Brake squealing, wont lock up, pads change doesn't help
As per the title really, I've cleaned the rotors with IPA, sanded the pads, changed the pads, tried to bed them in (not easy when you live in the Fens), and have done a bleed but nothing improves them much. After bedding in and they're hot they work a little but are still noisy and are back to not working again when I next try them.
Deore 615 if it helps.
Posted : 26/07/2016 7:30 pm
I don't know much about pads but changed mine to some Superstar Kevlar types and found the squeaking went. Might be lucky but perhaps worth looking at compunds.
Posted : 26/07/2016 7:35 pm
Faulty I bet. Had this with a couple of sets off deores. The square o ring seal was damaged from new which resulted in a very fine atomised mist of oil being squirted under pressure all over my nice new discs and pads. Was such a tiny amount that it was impossible to notice....
Lbs sent me new caliper and after I installed and re bled problem went away.
Posted : 26/07/2016 7:36 pm
Should have said that have had SS kevlar and EBC organic pads with same result.
Could be that doncorleoni, out of warranty but they are cheap I suppose.
Posted : 26/07/2016 7:46 pm
Same issue with the road callipers as well. My Ultegras had that problem. 3 sets of pads (courtesy of the shop) and a warranty replacement later and no further issues thankfully.
Is the rotor contaminated again after 1 ride? Suggests it's the same problem.
Posted : 26/07/2016 9:59 pm
Changing the caliper appears to have sorted the problem; no squeal and can skid like a kid ๐Ÿ˜›
Posted : 31/07/2016 8:31 pm
Always good to know something worked, add to the knowledge bank
Posted : 31/07/2016 9:03 pm
