Brake mount adapter...
[Closed] Brake mount adapters....
....it's fine to run a 203 post mount adapter w/ a 200 rotor....isn't it?
Posted : 04/05/2010 8:59 am
keep the dream alive. bump.
Posted : 04/05/2010 9:29 am
yes, but you'll lose 3mm of braking surface where the pad is too far out from the hub.
On my brakes theat's about a third of the pad area so you'll lose a lot of efficiency.
Posted : 04/05/2010 9:34 am
Seems to depend on the individual bits, especially if you are mixing brands. I'm running a 185 rotor with a 180 adapter and the alignment is ok, much better than it was with a 180 rotor.
Posted : 04/05/2010 9:37 am
