Brake lever reach
Brake lever reach
Is it possible to narrow the distance between bars and lever on a set of hydraulic brakes when the lever adjuster is adjusted as far as possible but they’re still too far from the bars?
Posted : 02/02/2025 4:04 pm
What brakes
Posted : 02/02/2025 4:39 pm
Surely if they are any closer than the current designed minimum distance you wouldn't have any 'void' to pull the lever into when actually using the brakes?
Posted : 02/02/2025 5:15 pm
thols2 and thols2 reacted
Theres loads of room. Ive got long fingers and they’re still too far out. Theyre Trktro ones i think.
Posted : 02/02/2025 5:19 pm
If you have long fingers and they are adjusted in as far as possible, yet are still too far away, then there is something very wrong going on somewhere in my opinion.
Posted : 02/02/2025 5:29 pm
thols2, dove1, J-R and 5 people reacted
Sounds a bit odd that brake levers set to minimum reach are too far away for someone with long fingers.
What brakes and what bars are you using?
Posted : 02/02/2025 5:50 pm
Pics would help of the setup you've got currently.
Posted : 02/02/2025 6:09 pm
Carefully bend the levers
Posted : 02/02/2025 10:32 pm
How low are your levers positioned?
What you have described doesn't compute in my simple brain and I can only think your levers are pointing downwards vertically?
Posted : 02/02/2025 11:01 pm
Heat and bend the levers. Or try and crash in the exact right way.
Does sound weird though, very few brakes don't have enough adjustability for stubby fingered people never mind long fingered elfs.
Posted : 02/02/2025 11:21 pm
I've never seen a set of brakes which couldn't be adjusted to come too-far in if you wanted to, which makes me suspect there is something else wrong, maybe a sticky piston, of too much fluid (pistons weren't pushed back) when they were bled?
Posted : 02/02/2025 11:33 pm
too much fluid (pistons weren’t pushed back) when they were bled?
This is the only thing I can think of that would cause the problem.
Posted : 03/02/2025 12:32 am
Are we talking about MTB bars here, or road/Gravel?
Posted : 03/02/2025 6:56 am
